the pilot, needle, and main are set to honda manual specs for elevation and temp.
toward the end of my last ride, the only way i could get my bike started (it was HOT) was choke on and 1/4 throttle and the bike stalls on long uphills
the lean condition is causing it to run really hot.
either the float is sticking or the level is off, right? or bad slide a possiblity?
anything else that i might be overlooking?
been chasing this carb issue for a while now. Sudco is not far from where i work....might take the carb in to show the experts...
