Been having an issue with my carb, since I cleaned it When ever my bike is running I have fuel coming out my over flow; not a lot, but a steady drip. When it os not running I have to lean it over, before anything comes out. I have played with the float level, which may be right or may be wrong as carbs are my weak point
Any ideas, tips or pictorials on float adjustment?
39mm PWK issue
- eyesky2002
39mm PWK issue
MXMotoworx.com
2003 Honda CR500AF
MXMotoworx.com
2003 Honda CR500AF
Re: 39mm PWK issue
you need a new needle and seateyesky2002 wrote:Been having an issue with my carb, since I cleaned it When ever my bike is running I have fuel coming out my over flow; not a lot, but a steady drip. When it os not running I have to lean it over, before anything comes out. I have played with the float level, which may be right or may be wrong as carbs are my weak point
- eyesky2002
Re: 39mm PWK issue
I checked it and the rubber on the needle looks great and the metal has no wear like shown below.craigf40 wrote:you need a new needle and seateyesky2002 wrote:Been having an issue with my carb, since I cleaned it When ever my bike is running I have fuel coming out my over flow; not a lot, but a steady drip. When it os not running I have to lean it over, before anything comes out. I have played with the float level, which may be right or may be wrong as carbs are my weak point
MXMotoworx.com
2003 Honda CR500AF
MXMotoworx.com
2003 Honda CR500AF
how is the spring?
It definately is a float/ float needle issue, keep looking there.
I replace mine every few years as the rubber dries out, even if it looks good it can act up.
Does your engine vibrate excessively? headstays are tight?
sounds like needle is bouncing when its running, but works fine when off.
Are your reeds in good shape?
a broken reed can allow the primary compression to wreak havoc on your carb too, as the flow is reverting with each compression stroke.
