Joe and I played hookie from work today, and got this project going...
Here is the swing arm alignment, ALL HONDA OEM BUSHINGS AND SPACERS! After some trial and error, I have found the Honda part numbers... Sweet!
The engine mount bolt WAS inside the frame cradle.. not any more! No welding required. The secret? I'll spill it later...
Same story on this side.
THe "Y" isnt going to be moved, just altered. It was ground for basic clearence to fit the motor. Ron will finish the reworking, and finish weld it back to stock.
The entire bike will look stock, like right out of Japan. Thats the key to any conversion I think.
Crappy photo of the perfect chain alignment.
Like I said 3 hours in, still have the make the head stay, coil bracket, pipe mount, tank reform and reassemble.
The bike should be done this weekend. Maybe 20 hours total.
After this one, its time to do mxracr121's frame, then Jays, then mine, then ???
Joe did a great job on the conversion so far...
These gen 3's are a piece of cake!
