pwk slides? what is the best number to use?
- high velocity
Ok i got a 39 pwk off ebay that was on a ktm 125.That carb has a #55 slide and seems to rich from1/8 throttle to 3/4 throttle.48 pilot ,168 main . dgh needle. What number slide are you guys running?
						Take a look at the picture below, taken from Keihin's site, as well as read up on the link.
http://www.keihin-us.com/tune1.htm
- high velocity
the slide cut away regulates the amount of air drawn over the needle jet at about 1/4 throttle.  If you  ride a lot at partial throttle openings like I do (semi tight woods) it does have some effect.   If you whack the throttle open most of the time you probably wouldn't notice much.   My gut tells me a 6.0 would work a little better for me but its not 50 bucks worth of better.
									09 TTM CR500AF
08 KTM 200 XC
08 Ducati Hypermotard
03 CR125
95 CR250
83 Husqvarna 125 XC
73 Maico MX250
						08 KTM 200 XC
03 CR125
95 CR250
83 Husqvarna 125 XC
73 Maico MX250
- high velocity
