Something kind of crazy to think about.
- NightBiker07
sometimes, when you think of that piston moving around in the cylinder, you wonder how it isnt creating a sonic boom cause its moving so fast.
take the stroke and max RPM of the 09 450R
62mm
11270 RPM
62mm x 2 = 124mm of travel per revolution.
.124 x 11270 = 1379.48 meters of travel per minute.
1379.48 x 60 = 83848 meters traveled per hour.
divide that by 1000 to get 83.84 kilometers per hour.
converted to MPH, you get 52 miles per hour.
yep, your piston is only moving around 52 miles per hour at max RPM on a new breed 4 stroke.
yeah, its fast, but when you consider a high power rifle bullet moves in excess of 1000 meters per second, which equals out to be 2200 or so MPH, the speed of that piston seems kind of paltry doesnt it?
62mm
11270 RPM
A bullet doesnt accelerate then stop dead then accelerate 22,000 times a min, to me thats the amazing part.
F1 at 24,000 rpm are the motors to look at if you wanna talk about serious piston accel/decel.
- CR500R7
Forgive me if I am wrong, but you have woked out the average speed of the piston.
If I am correct the instaneous speed of the piston is much greater, it has to stop and start twice for each revolution.
I did know the formula for working out the instaneous velocity of a piston, but that along with a lot of other knowlege has been losted.
- CR500R7
britincali wrote:A bullet doesnt accelerate then stop dead then accelerate 22,000 times a min, to me thats the amazing part.
Yes they are pulling 24,000 rpm but they have a really short stroke, so the speed they attain may not be as fast as you think.
Try a big block Chev pulling 9,000 rpm that would be some serious piston speed / instaneous velocity.
- NightBiker07
oh, i am well aware of the rapid acceleration/deceleration a piston undergoes, and it boggles my mind for sure. I wonder how much the piston"weighs" as its changing direction and throwing probably hundreds of G's onto the rod. i just never imagined that it was only moving at 50 some miles per hour.
- CR500R7
Yes you right it is amazing what is happening inside an engine, unless you work it out you won't know how fast or slow it is actually moving.
To be honest I have never sat down to work out how fast a motorcycle engine would be going, thanks for the thoughts though.
- NightBiker07
Velocity and speed are 2 different things entirely. the max speed of the piston is 52MPH, regardless of how many times it starts or stops. because every time it stops, it decelerates from 52-0MPH, and every time it accelerates it goes from 0-52MPH.CR500R7 wrote:Forgive me if I am wrong, but you have woked out the average speed of the piston.
i know exactly what you are getting at, but you are definitely thinking of the velocity, not the speed. and since i suck ass at physics, i cant calculate velocity, and even if i could, since we dont apply velocity to everything we do, the large value for the piston's velocity would be meaningless as we would have nothing to compare it to in our daily lives.
knowing what that 4 oz. piston (or whatever weight that piston is) exerts when it is changing direction would be an interesting figure to know though.
- CR500R7
I wasn't trying to give you a hard time, I was good at physics but I can't remember all the shit I need to work this crap out at the moment.
Obviously you understand what I am getting at, but I may of got it a bit mixed up.
If I could remember this shit it would make a lot more sense.
Sorry I wasn't trying p!$$ you off.
racein01 wrote: ...it was increadable.
If you havent yet you should see them in real life, it was a life changing day for me the first time, kinda like an 8th wonder of the world
- NightBiker07
oh, you didnt irritate me in the slightest man, it actually made me think about what you were saying. and yes, you are right, the velocity of those and the G-forces exerted are nothing short of a wonder.CR500R7 wrote:I wasn't trying to give you a hard time, I was good at physics but I can't remember all the shit I need to work this crap out at the moment.
Obviously you understand what I am getting at, but I may of got it a bit mixed up.![]()
If I could remember this shit it would make a lot more sense.![]()
I hate the internet, cause tones can get mis-interpreted, sorry if the last post came off as being irritated
- redrocket190
Speed is change in distance over time, Velocity is the same with the added component of direction. So in this context speed is interesting, but velocity is very interesting. It is the G-force around the change in direction at TDC and BDC that is the big engineering challenge in high-revving engines.
Michael Stiles
2007 Honda CR500R-AF
- NightBiker07
Too bad Danny's bike cant say the sameCR500R7 wrote:Well it's a good thing that CR500's don't have a valve train, less shit to break.
Brit forgot to tell you,...... you forgot to add this into the equation of lost knowledge.CR500R7 wrote:Forgive me if I am wrong, but you have woked out the average speed of the piston.
I did know the formula for working out the instaneous velocity of a piston, but that along with a lot of other knowlege has been losted.![]()
NightBiker07 wrote:Too bad Danny's bike cant say the sameCR500R7 wrote:Well it's a good thing that CR500's don't have a valve train, less shit to break.
the real wonder about engines at high rpms are the connecting rods, those damn things go through hell! if you've ever seen a motor turning , but open so you can see it, it just looks like there are so many forces trying to destroy those rods.
- NightBiker07
there ya go. then drop about 3 teeth in the rear to keep the same ratio, and kaboom, problem solved.dannygraves wrote: but puts a lot of chain pressure on the sliderIf the TM starts to wear quickly, I will just run a 14t front.
