CRF250X clicker settings?
yota
Post by yota »
yo Bob, do you have the base line clicker settings for fork and shock? Mine are 2006 and I don't have a manual for the X. Also I assume that these have adjustable fork preload like my other set of Showas (haven't tried to turn it yet and I'm at work) and if you have the manual what is the stock fork preload setting?
thanks!
09 TTM CR500AF
08 KTM 200 XC
08 Ducati Hypermotard
03 CR125
95 CR250
83 Husqvarna 125 XC
73 Maico MX250
Re: CRF250X clicker settings?
yota wrote:yo Bob, do you have the base line clicker settings for fork and shock? Mine are 2006 and I don't have a manual for the X.
2004 specs.....
Fork:
Compression- 10 clicks out from full in
Rebound- 7 clicks out from full in
Shock:
High speed compression - 2 turns out from full in
Low speed compression- 12 clicks out from full in
Rebound- 15 clicks out from full in
yota
Post by yota »
that will get me in the ballpark. thanks!
09 TTM CR500AF
08 KTM 200 XC
03 CR125
95 CR250
83 Husqvarna 125 XC
73 Maico MX250
Add two more clicks to the harder side of the rebound in the rear. Slowing it down will keep her from bucking you off. :lol:
redrocket190
Post by redrocket190 »
20004-2005
Fork spring length - 495mm
Fork oil - 345ml 5w
Fork damper oil (cartridge?) - 192ml
Compression - 7 clicks out
Rebound - 10 clicks out
Shock spring length - 254.4mm
High speed compression - 1-7/12 -2-1/12 clicks out
Low speed compression - 13-16 clicks out
Rebound - 13-16 clicks out
2006-
Fork spring length - 500mm
Fork oil - 340ml 5w
Rebound - 13 clicks out
Shock spring length - 256.6mm
High speed compression - 1-3/4-2-1/4 clicks out
Low speed compression - 12 clicks out
Rebound - 12-15 clicks out
Michael Stiles
2007 Honda CR500R-AF
yota
Post by yota »
a little change from 05..thanks!
09 TTM CR500AF
08 KTM 200 XC
03 CR125
95 CR250
83 Husqvarna 125 XC
73 Maico MX250
redrocket190
My guess it you are a) heavy enough to warrant a change in spring rate and/or b) do anything faster than woods riding, you're going to need to treat the X settings as a jumping off point only. I'm only 179lbs but I have a set of stiffer forks springs on the bench, and have already upgraded the shock spring. I stiffened the compression at both ends to compensate. I'm shaking the money treat to fund a re-valve by one of the obvious SoCal suspects (Racetech, Factory Connection etc.)
Michael Stiles
yota
Post by yota »
redrocket190 wrote:My guess it you are a) heavy enough to warrant a change in spring rate and/or b) do anything faster than woods riding, you're going to need to treat the X settings as a jumping off point only. I'm only 179lbs but I have a set of stiffer forks springs on the bench, and have already upgraded the shock spring. I stiffened the compression at both ends to compensate. I'm shaking the money treat to fund a re-valve by one of the obvious SoCal suspects (Racetech, Factory Connection etc.)
yes I just wanted to make sure I had them at default settings when I started. I am a bit of a suspension freak and am pretty good at set up. I have had a lot of revalves done in the last 20 years and honestly wood stay away from the big companies like the ones you mentioned above. in cali I would use precision concepts. MX Tech is also very good.
09 TTM CR500AF
08 KTM 200 XC
03 CR125
95 CR250
83 Husqvarna 125 XC
73 Maico MX250
yota
Post by yota »
I set my sag last night and the stock springs are fine, got to my number and still had 34mm static sag. I am starting at 100mm rear and guessing I will probably end up around 94-95 by the time I'm done testing sunday. I was at the doctor the other day and was at 173 lbs in street clothes.
09 TTM CR500AF
08 KTM 200 XC
03 CR125
95 CR250
83 Husqvarna 125 XC
73 Maico MX250
