engine coatings
W.M.F.J
engine coatings
Post by W.M.F.J »
I'm rebuilding a 91 motor and I want it to be really reliable since I race the usra desert series. and don't want to rebuild it very often. I wouldn't mind getting better performance but my main goal is reliability. so I was thing of using some coatings. any other advice would be great.
Have any of you guys used any engine coatings ?
this is one that a friend told me about
http://www.swaintech.com/
Wheelie-Gene
Post by Wheelie-Gene »
I fabbed up several Chevy V8 twin turbo systems the last few years.
I'm in the process of building a TT/BB 461 for my Camaro. I had my pistons thermal and dry film coated.....I'll eventually have the chambers, runners and valves coated as well.
I side-lined the Camaro to get my bikes in order. I did send the piston and head for the 500 out for thermal and film coatings.
Having less heat absorbed into the engine and expelling more out through the exhaust is a win/win situtation.
Dry filming the skirts takes reliability one step farther.
I have always believed in coatings but I don't personally know of anyone else that does it. The racers/hot rodders around here wouldn't even think of the idea.
Get drunk and slap parts together....yes.
Think up precision and high-teck shit...no way.
The place I use is just a day away....on UPS.
2nd gen SSS street hooligan
83 CR480
83 XL600
97 VFR750
Kawasaki H1-F
Suzuki Titan
HondaHarley
83 CB1100F
This is the only coating you need.....
Only thing I would do otherwise is magnaflux all the tranny parts.
Friggin motor is bulletproof.....
Wheelie-Gene
AlisoBob wrote:This is the only coating you need.....
Never seen the stuff anywhere....where do you get it?
What ratio?
How much smoke?????
83 CR480
83 XL600
97 VFR750
Kawasaki H1-F
Suzuki Titan
HondaHarley
83 CB1100F
2strokes4ever
Post by 2strokes4ever »
Is that stuff a treatment that goes through the bike, like Slick 50 teflon, or is it a 2 stroke premix that you run all the time
Two bangers, Guitar playing, Many beers
1996 CR500/2001 CR250 CONVERSION IN PROGRESS
2007 RM250
2010 Banshee
2004 CR 85
Wheelie-Gene
Pre-mix.
83 CR480
83 XL600
97 VFR750
Kawasaki H1-F
Suzuki Titan
HondaHarley
83 CB1100F
Wheelie-Gene wrote: Never seen the stuff anywhere....where do you get it?
What ratio?
How much smoke?????
Anywhere
32:1 / 40:1
Jetted properly.... not too much smoke.
caseyracing222
Post by caseyracing222 »
sorry Bob but im a fan of bel ray oils, they work really well for me. I have tied Maxima lubricants and have had bad experiances with them in the past, just my $.02
-Jake
It wasent the lubricant.
caseyracing222
I know your talking about the premix, I have never tried 927 before, I have been using MC1 for 13 years, but I have used Maxima's tranny oil and was very un happy so I am hesitant about their other oils
-Jake
Wheelie-Gene
I've never tried castor oil. I've heard stories form the old racers on how they are addicted to the smell and how good it is.
My first oil burner was a 79 Elsie, the first oil I burnt was MC1.
My first modern bikmewas an 83 CR250, I ran the MC1 at 32:1....which is waht Honda recommended. It blubbered and smokes so bad that I couldn't stand to ride it. So I slowly leaned down the mix, and at 50:1 (BR's recomended ratio) it came to life and smoke was minimal.
I got away from MX bikes for 20+ years, and the old MC1 craving krept up on me. That's when I scored the 480. Lucas 2stroke was the only oil available for the first ride. I couldn't stand the shit....I needed MC1.
The first time I took a whif of that smoke all the old memories came back.
So yeah, I can relate to MC1, that's all I've ever used.
As for tranny oil.....it's either Mystik or Rotella.
83 CR480
83 XL600
97 VFR750
Kawasaki H1-F
Suzuki Titan
HondaHarley
83 CB1100F
caseyracing222
Wheelie, I feel the same way MC1 performs the best at 50:1 and your motor lasts a long time too. I like belrays gear saver for the tranny its 80w it shifts smooth and lasts.
-Jake
Mate of mine had a YZ250J loved MC1 ran it at 55:1 and also used belray gear saver.
Never had any problems.
Brit I am not saying this is not " the best oil you have ever used while you are having your period "
927 is the best oil ive used period.
MICK
Re: engine coatings
Post by MICK »
W.M.F.J wrote:I'm rebuilding a 91 motor and I want it to be really reliable
Take your time, do the research and spend the loot to rebuild it correctly. All the engine coatings in the world can't save a piss poor rebuild.
That being said, could it have been the coatings that saved my motor last fall during a race when my water pump seal shit the bed and I pissed all my coolant out until I was dry, finishing the race oblivious to the fact? Maybe.
Post by M.F.D.B. »
I have used coatings for a few years here and there with mixed results. Currently, I have my Fo Fitty 13:1 dome heat reject coated and the skirt friction coated. If this top end lasts (3+ years/4-8 hundred hours) like the OEM did then ill let you know how it worked in a few years. :wink:
I had my dad coat a header on my sis's qwad to keep heat down (runs next to her leg) but it burned off after a few rides. Same place did the header that has done our coatings for the last few years, not sure why it failed.
There isn't any design issues with the 500 (besides the cast piston cracking that any not so well upkept motor could suffer from). The thing with coatings is they really wont hurt much even if they dont improve anything so if you are willing to put up the cash do it.
