Axle Shims
searcher415
Axle Shims
Tried doing a search to find the dimensions of gen 2 axle shims with no luck. What is the width and o.d. of the shims?
Width is 6mm on one side and 4mm on the other. OD doesn't really matter but can be ~22-25mm. ID is 17mm.
http://bannedcr500riders.com/board/view ... torder=asc
Here's an example of the "kits" that used to be available. you can see the spacers:
