2 stroke pipe repair
- DPinDet
I have a pipe from my CR250 that has a good size dent in it from a tree. I know I can send it off to various folks to get it repaired, but I am the kind of guys who likes to learn to do things myself. I have tried the water and freeze method with little results, if any. Has anybody tried to heat the area and use the compressed air method? If so, how much air pressure? Comments ?
DPinDet
DPinDet
"Trees are for traction"
south central hoon
Re: 2 stroke pipe repair
I have a friend that is amazing using the compressed air method. not sure how much pressure, but i would start slow and build up pressure till she pops.DPinDet wrote:I have a pipe from my CR250 that has a good size dent in it from a tree. I know I can send it off to various folks to get it repaired, but I am the kind of guys who likes to learn to do things myself. I have tried the water and freeze method with little results, if any. Has anybody tried to heat the area and use the compressed air method? If so, how much air pressure? Comments ?
DPinDet
Like this...
In french:
In french:
MODE OPERATOIRE
1 Mettre en place les deux brides
2 Mettre au rouge la surface concernée (chalumeau ou bec gaz)
3 Envoyer la pression (5 bars Maxi) et vous voyez la réparation se faire en 1 clin d'oeil , le métal reprend sa position initiale
Il faut aussi tapoter sur les bords avec un petit marteau là ou la tôle est la plus froissée ( au bord du cratère ); c'est à dire qu'il faut être 2 pour l'opération 1 qui gère le chalumeau et l'autre la pression et le marteau
CRF450R SuperMotard.
CR500AF SuperMotard under construction.
- asteroid500
my mate dose hundreds a year in Melboure, Australia.
100psi......NO im not kidding.
i was taut by him to do it and ive never blown one out.
if only i could wire weld as good as him.(oxy)
CR250 97
CR500 AF 99 (in progress)
CR500 AF CR G-4
CR500 1985 true legend
RGV250 96 X2
GSXR600 07 TRACK BIKE
VH Commadore cup car (race)
CR250 97
CR500 AF CR G-4
RGV250 96 X2
I made plugs for both ends of pipe. Drilled and tapped the cyl. end plug to accept a male air fitting to connect the shop air hose to. I regulate the pressure @ 50-60psi. I think it is a good idea to "burn out" the pipe before plugging the ends and heating because it could become very explosive(the oily spooge inside) if you don't. Plug ends and apply pressure then use torch to start heating the dent. make circles around the dent starting on the outside and working towards the center. You have to get the metal good and red before the dent starts to slowly rise out.
Thats a must if you get a fire going in the pipe from the left over oil and carbon its not pretty! It can melt your plugs out and cause the pipe to blow out and be completely ruined not to mention the molten metal flying around!KE 336 wrote:. I think it is a good idea to "burn out" the pipe before plugging the ends and heating because it could become very explosive(the oily spooge inside) if you don't. Plug ends and apply pressure then use torch to start heating the dent. make circles around the dent starting on the outside and working towards the center. You have to get the metal good and red before the dent starts to slowly rise out.
Just get a dial regulator and put it in-line like you would on a paint gun so you can set the pressure accurately and safely.
1982 XR200
1985 CR500 86' Motor
1990 CR500 85' Motor
2000 CR250
2000 CR250
