steelie only $7500
steelie only $7500
2003 crf450r
thats the same dipshit that posted it on ebay and likely had a buddy bid it up, i forget where that thread was, its the same pics with no swingarm bolt, bid # 250362798075, excepththe buy it now price was 7000. I save the page too
"This bike is a 1997 CR500R that has been completly rebuilt. THIS IS A NEARLY BRAND NEW BIKE FOR THE SAME COST AS IT SOLD FOR IN 2001!!!!!!!!!! YOU CANT BUY THESE ANYMORE..... Own a awesome classic!!! Forget the Aluminum Framed Frankensteins...... this is an orginal.
This bike has 15 Minutes Break In run time. NO DIRT TIME AT ALL!!!!!
This bike was stripped completly down to the frame and was powder coated factory white. All the plastics including the tank are NEW HONDA. All mounting hardware has been replaced with NEW HONDA parts. Every nut, bolt, washer, zip tie have been replaced with NEW HONDA parts. Every fastener had been torqued per factory spec. All fastners that require loc-tite have also been done per HONDA spec..... the right color loc-tite for each fastner.
All the plastics and parts used are NEW HONDA and have updated this bike to 2001!
The engine has been completly rebuilt with new top and bottom end including the entire transmission...... the bottom end and transmission were done by Pro-Circuit. The top end port and cylinder work was done by Eric Gorr of Forward Motion Industries.
Pro Circuit set up the suspension for a 200 lbs experienced rider for desert. All new internal parts and springs. Rear shock has new spring and bladder cap as well as completely rebuilt
The engine has a Cool Head, 39.5MM Keihin PWK Air Striker Carb, and Boysen RAD Valve. It is putting out just under 79 HP.
Hinson Clutch Basket. Barnett Kevlar Clutch Set (New Steel, Friction Plates and Springs)
The wheels are new Warp 9 with new stainless brake rotors.
NEW FASST Flexx Handle Bars (These Things are great!!!!!)
ASV Levers, Clutch and Front Brake.
IMS Pro Foot Pegs
All bearings and seals are new throughout
Wheels
Steering
Swing Arm
Rear Shock Pivot Point
Radiators are NEW HONDA, not knockoffs.
All fluids are HONDA. Oil, Coolant, Brake fluid, etc......
If you use the buy it now function....... Ill throw in all the parts that came off this baby during the project
Stock plastics
Carb
Fuel Tank
Radiators
Wheels
Tires
Handle bars
and much more.
I know times are tough.... thats why Im selling.... I have $9500.00 into this bike over the last 5 months and countless hours........ but here is a rare chance to own a COMPLETLY REBUILT with ALL NEW HONDA PARTS CR500!!!!!!!
If you in the local area come take a look...... If not tak a look at the pics!!!!!
All work completed by 25 Year mechanic in a professional work area. NO SHADE TREE WORK HERE!!
CAN YOU HANDLE THIS BIKE???? AMATURES SHOULD NOT EVEN CONSIDER BUYING THIS BIKE
On Jan-25-09 at 09:58:08 PST, seller added the following information:
I forgot to mention:
I have the Pink Slip (Title) in Hand and it is clear.
NEW Sprockets (2 Sets 13/49 and 14/51)
NEW RK Chain
NEW HONDA seat (not just a cover, the whole assembly)
NEW HONDA Airbox, boot assembly and hardware (entire assembly)
NEW Twin Air Air Filter
Work's Connection Frame Guards
IMS Shifter
Service Honda Clutch and Ignition Covers
NEW HONDA Fluids throughout including brake sytem
NEW Honda Brake Pads
All NEW HONDA Cables (Clutch and Throttle)
NEW HONDA Throttle Assembly
NEW Honda Kill Button.
NEW Bridgestone Front and Rear Tires
NEW Heavy Duty Bridgestone Tubes
The FLEXX handle bars are a $400.00 set-up alone.
As the bike was being reassembled all threads were cleaning and chased using metric dies. (To avoid stripped or cross threaded bolts as well as allow for proper torque)
The Frame was bead blasted, acid dipped and Finished with Outdoor (UV) Industrial Powder Coating
I also have all the receipts for the parts and work I've done..... All HONDA or Industry Leading Parts (NO KNOCKOFFS)
This bike is near Museum Quality.... but she deserves someone to ride her the way she wants to be ridden......
I wanted a NEW bike, the CRF450 doesnt do it for me.... This bike is the "muscle car" of dirt bikes... Im selling this bike for less than a New CRF450 and less than Service Honda's Aluminum Frankenstein's!!! Ask yourself this...... If a 500 engine in a Aluminum Chassis is the hot ticket then why didn't Honda pick it up???
I also have a NEW graphics Kit the goes with the bike. Its made by AMR, see the link below (sells for $149.00)
http://cgi.ebay.com/ebaymotors/AMR-GRAP ... ccessories
If you need to ship this bike and your shipping company does not offer crating, I will have it proffesionally skid mounted for an extra $150.00 and deliver it to any shipping terminal within 50 miles of Zip Code 92501.
Anyway, you get the idea. This is a very rare opportunity to pick up a CR500 in this condition. GO ahead, shop a deal. If you want a CR500 and appreciate what they are then this is the bike you want. I will answer any questions you may have so please feel free to email me."
IMS Pro Foot Pegs
Wheels
Steering
Swing Arm
Stock plastics
Carb
Fuel Tank
Radiators
Wheels
Tires
Handle bars
and much more.
NEW RK Chain
IMS Shifter
- teamdns
amazing huh?
when it was relisted the bid shot to around 4,500 quick its back at 5k
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0366263186
_______________
Ryan
Ryan
- xtremeslide
he's had 1675 views
