Bearing Question
kkvslayer
Bearing Question
Post by kkvslayer »
I got my new tranny bearings yesterday,I know I can use the heat/freeze method for putting the new ones in but how do you guys get the old ones out without a puller?
1994 Heartless CR500R
1986 KX500
I could be a smartass and say just drive em through the case with a hammer but wont
"SOLID Bro!!"
Post by "SOLID Bro!!" »
The same way. hot plate or oven.
kkvslayer
Post by kkvslayer »
lewisclan wrote:I could be a smartass and say just drive em through the case with a hammer but wont
:lol: I think I'll try "Solid"'s method first
1986 KX500
heat the shit out of the cases and they pretty much just fall out :wink:
Last edited by dannygraves on September 26th, 2008, 9:49 am, edited 1 time in total.
If your a good welder, weld a bead around the edge of the bearing.
It will shrink the bearing, and it will just fall out.
NEVER REMOVE / INSTALL THE BEARING BY JUST BEATING ON THEM
The interference fit is crutical to long life. If the bearing spins, the motor is junk in a short amount of time.
Heating the cases, and "Dry Icing" the bearings works awesome to install.
I just leave the bearings in the freezer in the beer fridge over night before assembly.
"SOLID Bro!!"
AlisoBob wrote:If your a good welder, weld a bead around the edge of the bearing.
Does the bearing shrink ? Or does the heat transfer to the case and the case expand?
kkvslayer
Post by kkvslayer »
When I split my 86 cases a couple days ago the 2 smaller bearings on the tranny shafts just fell out so I guess those cases are junk eh?
1986 KX500
na, those 2 smaller ones aren't a press fit. this is a good thing since one doesn't have access from behind.
every pair of cases I have split has had those just fall out.
kkvslayer
Post by kkvslayer »
dannygraves wrote:na, those 2 smaller ones aren't a press fit. this is a good thing since one doesn't have access from behind.
The ones on my 87 cases are not just falling out,mind you I havn't really tried to take them out yet,I just tugged a bit with my finger and they didn't move so I figured they were press fit also
1986 KX500
[quote=""SOLID", Bro!"]
Does the bearing shrink ? Or does the heat transfer to the case and the case expand?[/quote]
The weld shrinks when it cools and pulls the bearing with it, only try this if you know how to weld :wink:
It shrinks as the weld cools. You can come back after a hour, and the bearing will still fall out.
Re: Bearing Question
kkvslayer wrote:I got my new tranny bearings yesterday,I know I can use the heat/freeze method for putting the new ones in but how do you guys get the old ones out without a puller?
ALL the bearings in the bottom end are "supposed" to have interference fit, with the exception of 1 bearing in the right case, and 1 bearing in the left case...these 2 bearings have a tab that holds them in place but they too should have a near 0 tolerance fit. other than the 2 "tabbed" bearings, if ANY of the others just fell out you better fix that, other wise they will spin and fuk up the bore. actually if they just fell out that means they already have started to spin. to get those bearings out you need a blind bearing puller to get behind the bearing....rather than dropping huge cash on a qaulity bearing puller set i had my buddy at the dealer pull mine with his pullers (he charged me around $30 to remove all bearings including the 2 small clutch rod bearings which are a bitch to get in and out). $30 was pocket change since ill probly never have to replace any more bottom end bearings again in my life time. you could try the stove trick like others have mentioned, ive never done that to remove bearings so i cant comment on how well it works
on a side note: i would be very cautios when heating the cases. a map gas torch can and will waaaay over heat the case if your not carefull
Nate
Post by Nate »
I wouldn't heat with a torch. get it in the oven and keep checking it.
How can you fix the bearing from falling out? the welding trick?
Nate wrote:I wouldn't heat with a torch. get it in the oven and keep checking it.
i think bearing driver and press (with alittle heat) is the best way but not everyone has access to those tools, including myself. i used map gas/freezer to install all mine and it works fine but use common sense when using that hot of a torch. couple ways of keeping the bearings in there, provided the bore isnt wallered out....loctite has stuff like thread locker but its for bearings, i used a different method that worked good also
Loctite "GREEN" Bearing retainer :wink:
Nate
Post by Nate »
Ahh right i think i will try the loctite. cheers
kkvslayer
Post by kkvslayer »
Any tips for getting the screws off on the countershaft bearing retainer tab thingys :shock: I could of had my engine together if it was not for these things
1986 KX500
Impact driver.
yup, I got mine for like $7 at horbor freight, removed 2 sets of those bearing retainers last night :cool:
yup impact driver, and if i remeber correct honda puts loctitie on those screws so they will be a bitch to get out. and whatever you do becareful you dont strip out the philips head with that impact driver or youll have alot more work getting stripped screws out :lol:
I've got a jetwash at the shop, its like a giant dishwasher. That sucker will heat the casses and clean the paint from them in one shot, if I'm lucky the bearings have fallen out before I take it from the wash. Same to put them back together, I do like running my crankbearings on the edge of beeing loose. Loose is fast!
Post by M.F.D.B. »
I would not rely solely on Loctite with loose bearings. All you have to do is swedge them. Remember heat and oil trash Loctite...
kkvslayer
Post by kkvslayer »
Still havn't got those screws off for those retainers,I did discover that my cordless drill doubles as a Impacter but still no go,should I try heating the bearing with a torch to heat the area around those screws then go at it with the impacter?
1986 KX500
