Protaper bars and pro grip Iggys
I put these bars on today and some ProGrip grips that Iggy recomended for less vibs. Pretty sweet grips, need to wire them I think cause they have the grooves for it. Who has some wire and them fancy pliers? :shock:
thgose are the same ones I run
if you put grips on properly you dont need no stinkin saftey wire :P
i use brake cleaner give the grips a good shot slide them on and let them sit overnight... there will be NO slipping... and to remove... run a razor blade lengthwise and peel off.. clean off any rubber residue with brake cleaner again :P
Those are good lookin grips though. I prefer spyder grips.
aloha450x
Post by aloha450x »
the glue sucks. I just put my pro taper grips and had to wire them.
ou812
Post by ou812 »
X2
That's funny, the grips I just removed were Spyder grips. I liked them fine, but these are more cusioned to kill the vibs better. I was able to remove the old grips without cutting them though, so if I need to they can go back on. :D
these are the same ones I run.
Actually Rob129 gets credit for the grips.
Only prob I see with them is holding water and mud, usually not a prob out west. :lol:
I don't use the wire. Brake or carb cleaner works real good and you can lift up one side to evaporate the cleaner faster. :wink:
P&P you have the link to order them. I need a new set.
iggys-amsoil wrote:Actually AlisoBob gets credit for the grips.
Here is where I found thm the cheapest. http://www.casporttouring.com/store/mer ... ode=PG714R
ya, I walked into cycle gear and best cycle here in town, cycle gear had them for $9
Sorry Bob but I think Rob is the one that turned me on to them also , and now its the only grip I run on the bikes I ride
They are good for guys with HUGE fingers, Ive got stumps so I like thin grips :lol:
lewisclan wrote:Sorry Bob but I think Rob is the one that turned me on to them also , and now its the only grip I run on the bikes I ride
And where did HE hear of them?
:revolve:
( :wink: )
:revolve:
( :wink: )
:lol: :lol: :lol:
:revolve:
( :wink: )
It wasent Iggro so was it YOU!
Banned Bob @ www.cr500riders.com wrote:
Banned Hoon
Offline Forever
Yo, Yo ,Yo from
Baltimore
Boyeeeeee!!!!
Re: Your Favorite Grips
Reply #28 - Dec 24th, 2005, 6:47pm
These are the Rally "714" grips. They fit "big paws" well.........
http://www.progrip.com/default.asp?tip=8&ite=gri
It doesn't matter. I'm sticking with these unless something better comes along.
In Black http://www.casporttouring.com/store/mer ... rips/16313
Thanks
its all good
Slomo
Post by Slomo »
I run the slim grips and I have "big paws". Never had a problem with arm pump or vibes either.
Hit the gym and get in shape- best grip ever!!!!!!
slomas wrote:I run the slim grips and I have "big paws". Never had a problem with arm pump or vibes either.
X10 :mrgreen:
