IMS Tank
- redrocket190
IMS Tank
Has anyone put a larger IMS tank on their AF conversion. I need a larger tank for my CRF250X-based bike. Should I assume the bottom will need to be relieved etc....
Michael Stiles
2007 Honda CR500R-AF
from what i have seen, the oversize tanks on the motor side are the same as stock. so you will have to modify it just as much as a stock tank.
also the mid size IMS tank is the same size as the stock X tank. the 4 gal is just fuckin huge. if i were to by a over size tank for my CRF250R based conversion, id use an Acerbis (2.9gal) or a Clarke (3.0gal), both of which are cheaper than the IMS. BTW, if you order a Clarke, order it BEFORE march 1st, the price is going up to $210 from $180 on the 1st.
TJ
2005 cr500af
2008 300XC/w
2005 cr500af
2008 300XC/w
- redrocket190
