cylinder boring
mocr13
cylinder boring
Post by mocr13 »
ive got a question proably dumb but just need to know I was always under the impression that Honda went to the nikasil coated cylinders 1989 and if you had a cylinder before 1989 you could bore it if you had a 1989 or later you couldn't bore it at all, you had to resleeve it,but I see people talking about newer cylinders being bored out am I wrong in the 89 on cant be bored? or is something else going on that people resleeve then bore new sleeve whenever needed? any help with this matter would be greatly appreciated! thanks mocr13
The cr5 was never produced as plated bore
mocr13
Post by mocr13 »
thanks for the info! guess I was mis informed on the nikasil plating what is the farthest out a cr500 cylinder can be bored and not have any kind of issues with it?
mocr13
Post by mocr13 »
sorry guess I didn't explain myself well enough I mean how many thousands over stock can you bore a cr500 cylinder before it gets dicey? thanks
freeride588
Post by freeride588 »
stock is 89mm
biggest overbore is 91mm
Kevin
