converting a 2010 CRF-450?
Any comments on what needs to be done and how suitable is this bike is for shoe horning a 500 motor in it?
My last 500 was a 03 Service Honda 500 af. Was very happy with the bike, but their prices are very high now and I think I can do it myself pretty cheap comparatively.
probably the best chassis for a 500 EVER!
2009 I did
https://onedrive.live.com/?cid=BD4AA268 ... 2E9%214355
another 2009
https://onedrive.live.com/?cid=BD4AA268 ... E9%2141004
a 2011
https://onedrive.live.com/?cid=BD4AA268 ... E9%2141097
best advise is to not use the stock Y method, 1999 CR250 air boot on 1/2" poly spacer to airbox and moose reed spacer at the engine and tip that sucker down as far as you can. Stock rads clear FMF fatty pipe, aftermarket will clear nothing. SRS in the UK's hose kit for the SH af bike works great.
I do make some components to do this, so does MXbikeworx and Loudmouth MX.
2009 I did
another 2009
a 2011
The customer installed the tank after a few hours of riding. Where I had the CDI mounted needed relief on the tank, that was all.
The loudmouth one does not deal on the oversized tanks so I've made inserts like shown in my 2010 crf250 / 250 build.
Its a combination of shuffling from one end to the other but I am running a spacer on mine. I used a 1/8" plate at the airbox instead of the 1/2", 3/8" spacer on the reed now. Everything clears using the '99 250 airboot still.
Ron will also make you the pulse setup on a short bodied carb where you'd still use the 1/2" airbox plate. I like the long carb since it has the screw on cap, not the allen screw retained lid.
We are close to having conversion manuals completed for this conversion. I know that they are manuals using our parts, but it can give you an idea on different options. We do have our coil mount manual on our website. We basically just mount it to the right side where the OEM head brackets attach.
We also have airbox boot options. Our initial order should be here very soon. They are available for pre-order right now, though.
Thanks for sharing.
CP500
ConversionParts500
www.conversionparts500.com
Thanks for sharing.
CP500
ConversionParts500
