Bout to rebuild, need some help/opinions
				binder man
Hey all about to go through my 85 500. It appears to have had a fresh rebuild/low hours but it sat outside and the rings stuck. Hone looked good on it and crank seals look good. But while I'm rebuilding I'm sticking new bearings and seals in for good measure. My rod side clearance is .039" I'm waiting on a set of calipers to measure the piston so I know if it's been bored before.
What piston should I stick back in this thing? Are the pistons normally stamped if its a oversize? I've built tons of motors just no bike motors.
				binder man
It's not stamped on but I'm measuring roughly 90.25 or 90.45. I know calipers are a no no. I build motors lol just have no metric mics waiting to find a set. These motors although very simple are a new ball game to me. I'm use to 4.5" bores and you don't dare reuse rods based on side clearance lol that's why I came to the masters for help!
						- jbsleddin
- PVT. 1st Class
A quality measuring tape will suffice.AlisoBob wrote:Sorry.... calipers to measure pistons and cylinders is a no-no.....
 I don't think he was planning on using those #'s as clearance values. Probably just wanted an idea of where his engine was, bore-wise.
 I don't think he was planning on using those #'s as clearance values. Probably just wanted an idea of where his engine was, bore-wise.   You can go up to .080" over (91mm) but some people frown upon that.
						- Rhino89523
				binder man
				binder man
- Rhino89523
				binder man
- Rhino89523
No I'm not on the IH forums, Ive been playing with IH long enough I don't really need help with them. I picked up the king cab in Idaho...flew in bought it, drove to an auto parts store and bought some tools and then drove home. The travelall I bought 2 of for $500 and built one good one out of both. The one I built was actually a 4 wheel drive I turned into 2 wheel because the crew is my wheeler.....didn't need 2.
The travelall is about to turn into a cummins diesel.....crew will probably be next. Crew is 392 w 5 speed now but I drive them both almost daily and could use some mileage. The IH pureist's don't like me much so I usually stay away...at least their not getting chevy 350's!!!
I have 6 IH motors 7 trannys and 4 transfer cases so I'll probably need to build up a scout or something else. The IH's run good.
O.ne  B.ig  A.ss  M.istake  A.merica
				binder man
- Rhino89523
