Magura to CR500 part #
- asteroid500
DONT BAG ME.....
Iv'e done the search, spent 15mins reading posts ... thanks boB on a brilliantly edited bleeding process on the aforementioned device, even if it sucks arse!
So what Magura clutch do i get for a 500.
250 (97-00) clutch cables fit 500's so is it safe to assume .... i think not,
thats why im asking.
Im on Fleabay looking at geting one for my 85 steely.
CR250 97
CR500 AF 99 (in progress)
CR500 AF CR G-4
CR500 1985 true legend
RGV250 96 X2
GSXR600 07 TRACK BIKE
VH Commadore cup car (race)
CR250 97
CR500 AF CR G-4
RGV250 96 X2
- asteroid500
- asteroid500
The Magura web site is "SHIT"
There are 2 listings to suit the Honda CR500.
Generic 2 stroke kit.
Manufacturer Part Number: 0120493
Honda CR250R (does not specify yr)
CR500R 1987-2007
Suzuki RM125 1991-1993
KTM 250SX 300/360/380 1990-1994
Model specific.
Manufacturer Part Number: 1011630005
(250-500 are 2 separate listings)
Honda CR500R 1984–2001
Honda CR250R 1990–2007
Manufacturer part number: 1011630004
Honda CR125R 2000 - 2007
Interestingly has only the final digit different to the 250-500's P/N
Magura I
Magura II ( note the bleed nipple )
CR500R 1987-2007
Model specific.
Magura I
CR250 97
CR500 AF CR G-4
RGV250 96 X2
CR250 97
CR500 AF CR G-4
RGV250 96 X2
- asteroid500
- asteroid500
PM sentAngryShawn wrote:I've got one of these I got used for my 97 that I'm not going to use, sticking with my cable clutch and moose ez pull. Let me know if you are interested, I can dig it out and take pics if you like...
CR250 97
CR500 AF CR G-4
RGV250 96 X2
CR250 97
CR500 AF CR G-4
RGV250 96 X2
- asteroid500
http://www.mooseracing.com/catalog.jsp? ... up_id=7267asteroid500 wrote:Whats this piece of kit?AngryShawn wrote: sticking with my cable clutch and moose ez pull.
- asteroid500
any one got a picture of this mounted on there bike?
Last edited by asteroid500 on January 28th, 2012, 6:15 pm, edited 1 time in total.
CR250 97
CR500 AF CR G-4
RGV250 96 X2
CR250 97
CR500 AF CR G-4
RGV250 96 X2
- asteroid500
Like say where the Magura would go ... that's why im asking for a picture of one on a bike ....AlisoBob wrote:You dont "mount" it anywhere.... its inline.
Your opinion on them boB
CR250 97
CR500 AF CR G-4
RGV250 96 X2
CR250 97
CR500 AF CR G-4
RGV250 96 X2
The only one I rode was on Shanmans original Gen1 AF.asteroid500 wrote:Your opinion on them boB
It attaches to a standard clutch lever, and then the standard cable attaches to it... it kinda floats in space behind the number plate.
Inside ia a little lever with a few holes in it to determine how much mechanical advantage you want... but the more advantage it applies, the shorter the available throw.
It the max position, the lever pull is easy, but the cluth turns into a "light switch"... its either on or off.... pretty hard to modulate.
I think Shan had his in the middle position. It rode well, lever pull was pretty easy.
I'm not sure all this is really needed though... If you ever rode a CR500 with a ball bearing lever, new OEM cable, new lifter mechanism and pushrod, and OEM fibers and springs... the clutch feel is perfect and the effort to control it is pretty low.
Its a good system when all the parts are working as they should....
- asteroid500
