and now for something completly different! TRX500AF!
Kuma
Post by Kuma »
So here it is, Aluminum frame CR500 quad conversion.
Still a work in progress, just got the rear suspension set up, head stay and motor mounts next.Image
UknowDamright
Re: and now for something completly different! TRX500AF!
Post by UknowDamright »
Kuma wrote:So here it is, Aluminum frame CR500 quad conversion.
link just goes to the homepage
Fixed link for ya:
Looks Good!! :cool:
Curios how the vibes will be...
is it just me or are the tires on backwards?
UknowDamright
2strokeforever wrote:is it just me or are the tires on backwards?
yup, backwards....I saw a guy at the dunes this summer and I told him his were on backwards, he looked at me funny then said OH yeah I meant to put them on that way
UknowDamright
nice though :D
nice work
Kuma
Post by Kuma »
Yes the tires are on backwards, but only because this is still in process :)
This is a Cannondale frame, drive chain is on wrong side. For now I just flipped the axle and carrier over.
Kuma
Post by Kuma »
Want to thank Solid Bro for the idea of using the honda upper shock mount, still looking for another along with a swingarm to put another frame together.
I have read many topics on the CR5 vibrations in quad frames, some have tried rubber mounting, this only makes things worse. I am going with a good head stay, location should be close to the bike mount, I'm thinking for the bottom mount I may make it so that I can use a shoulder bushing bearing against the case, that way I can start out with aluminum, and have the option to replace with urathane or nylon, this would only allow for a very small amount of movement but may help prevent frame cracks. front mount design will be simular to the TRX mounts which have a little jog, I have to assume that the designers did that to make it a bit of a spring, can't hurt.
Factory cannondale bar mounts already have vibration isolators, I think that the fact that this will always be on sand will also help reduce the vibration. We shall see :?
Kuma
Post by Kuma »
hoofarted wrote:Fixed link for ya:
Looks Good!! :cool:
Thanks!
Roostius_Maximus wrote:nice work
X491
Gorgeous work. The thing Honds never made, but should have. I remember seeing a few different counter-balancer designs for CR500 based quads....
a guy on 3WW built this. I'm not a fan of the motor, but the work is sweet nonetheless.
jbsleddin
Post by jbsleddin »
Looks Good!! :cool:
Only good vibes off this bitch! And I thought quads were for fags! This must be the first time I've been proven wrong! :lol:
Rhino89523
Post by Rhino89523 »
Looks good Kuma, your arsenal of weapons for destroying sand is pretty sweet.
Kuma
Post by Kuma »
NightBiker07 wrote:Gorgeous work. The thing Honds never made, but should have. I remember seeing a few different counter-balancer designs for CR500 based quads....
I could have easily made a 3 wheeler using the CR swingarm as is :wink: would have been 2 in the front 1 in the back :roll:
I saw a thread of someone making a counterballanced 500 motor but they were going about it all wrong, If I were to try it I would use the counter balance out of an FL400 pilot, same stroke as the 500. I have no intrest in that project
Kuma
Post by Kuma »
Rhino89523 wrote:Looks good Kuma, your arsenal of weapons for destroying sand is pretty sweet.
Going to tear it up at Dumont this weekend, c'mon out!
nice. something dont look right about this one. motor sits straight up to much i think and front sprocket location dont look right http://forums.everything2stroke.com/sho ... hp?t=43797
Kuma
Post by Kuma »
100hp honda wrote:nice. something dont look right about this one. motor sits straight up to much i think and front sprocket location dont look right http://forums.everything2stroke.com/sho ... hp?t=43797
I've seen this one before, didn't pay much attention but it does apear that the sprocket is too low and will be constantly trying to saw through the chain guide and swing arm.
The motor in mine is tilted down a little more than when finished, right now it is just sitting on the cradle. it will still end up a little lower than preferred but got to fit the carb :D
AMA714
Post by AMA714 »
So is it actually lighter than the stock Fourtrax frame or a chromoly frame that you can get from Laeger's?
Just curious what the aluminum frame weighs
Kuma
Post by Kuma »
not making the amount of progress I'd like to on this but still moving forward.
Have the pipe mockup done, thanks to 396rsss for the help.
have not decided to weld it up myself or have Power Pros do it.
Kuma
Post by Kuma »
I will have to go with an internal tailpipe, from what I have read there is no disadvantage, pretty sure that is what some of the kart pipes use.
Kuma wrote:I will have to go with an internal tailpipe, from what I have read there is no disadvantage, pretty sure that is what some of the kart pipes use.
Kuma
Post by Kuma »
The tail pipe that we are all familiar with runs out the back to the silencer, with this one it will run back into the rear cone. after that I'll be looking on how to silence it, or just wear ear plugs :wink:
Took the mockup over to Power Pros today, I'm probably going to have Don complete the pipe for me, it will be around $350
Nodge
Post by Nodge »
:bong:
Kuma
Post by Kuma »
More pics with the new pipe.
Pipe was built at PowerPros, cost was $350, not $275 :cry:
Still, I've got to think of it as a bargin.
