Decomp valve
mr500
Decomp valve
Post by mr500 »
Have give a quick thumbs up to Larry W for the lovely job he did on 2 heads
Here's one.
[/url]Image
On the bike.
Keep it real, Keep it steel.
Tharrell
Post by Tharrell »
Nice, got a pic of the inside?
mr500
Post by mr500 »
As requested
[/img]Image
CR500PHIL
Re: Decomp valve
Post by CR500PHIL »
mr500 wrote:Have give a quick thumbs up to Larry W for the lovely job he did on 2 heads
Here's one.
[/url]Image
On the bike.
Beautiful - I wonder would it clear the side of my large Clarke tank.
Steelie Build Done
That head is like the ones I do also, most of the side mount ones didnt clear the big tanks, I had always installed them stair up before because of that. I did sell some side mount stuff that didnt need to be welded also.
I have a strait up install R casting head ready to go if you need one :wink:
CR500PHIL
Decompression
Post by CR500PHIL »
Roostius_Maximus wrote:That head is like the ones I do also, most of the side mount ones didnt clear the big tanks, I had always installed them stair up before because of that. I did sell some side mount stuff that didnt need to be welded also.
I still have a couple needs for upgrades throughout the fall and over the winter and this may well be one of them. I will contact you when I get ready to do this. Here is one thing I do not understand - if low compression causes difficult starting ( I experienced this first hand) then why doesn't a decompression valve have the same effect?
Steelie Build Done
mr500
Post by mr500 »
Who said its easier to start?.. Decomp means it's only easier to Kick!
Maybe its cos the mixture is going out the decomp valve and not back into the crackcase via the rings?
One thing i did notice is it's harder to find TDC wiith the valve in.
BIt like an xr400.
Better to find TDC first then push the button.
mr500 wrote: Maybe its cos the mixture is going out the decomp valve and not back into the crackcase via the rings?
:headbang:
Gmbond
Post by Gmbond »
Although my bike needs some jetting time spent still, I find the big difference on the decomp valve is it allows the motor to spin over a bit quicker. They still like an open throttle and a damn good kick, but with my still weak right knee I'd otherwise be leaning the handguard against a tree and having to stand on the peg for every start I think.
You use the decomp to get some kick momentum before returning the full cylinder compression. if the decomp stuck on, it would never start, similar to a low compression issue.
I dont understand how these work though. A lever operated one stays open until you release the lever. but how are you supposed to kick the bike and deactivate these decompression valves? I must be missing something here
Gmbond
Post by Gmbond »
these are a poppet style valve, you push it in and it "snaps" down...
when kicked they will stay open, but upon the first good pop or fire from the cylinder it kicks them shut. Sometimes if the bike pops/fires it will kick them shut before it starts and you need to reset the valve again to kick again. My Valve is on the right side of the cylinder head, so when i reach for the kickstarter its right at my fingertip to push in, it seems a little more natural on this side to me as i only need to use the one arm to get the kicker and the valve. Some people have rigged up cables to allow a bar mount hot start lever from a 4T to be used to bump it open, some of these setups are pretty damn sweet.
There are several different manufacturers of the valves, including some chainsaw designed ones... (STIHL)
AV&V
Goodson
S&S
Screaming Eagle
all make the same sort of style but i haven't got any clue what is best...
Gmbond wrote:these are a poppet style valve, you push it in and it "snaps" down...
AV&V
Goodson
S&S
Screaming Eagle
Got it. I know the 4 stroke hotstarts will stay open as long as you hold the lever.
The more i read into these, the more i want one for my bike.
Would you have any pics of a cable rig on one of these? that would be really nice to have. I just cant visualize hooking a cable to that little thing, especially if you push IN on the button
cbx1170
compression release
Post by cbx1170 »
How to get a hold of Larry W? he is at lwiechman@charter.net
mr500
Post by mr500 »
Don't expect to be writing pages of correspondance with Larry.. :D
Gmbond
Post by Gmbond »
Give him a call
815-623-8940
ya it could, mine does it every once in a while, also with a little throttle it will run with it open, i didnt pass soundtest so i held it open with my knee, and richened up the air screw, also put it in gear and kept a little load on it with the clutch, and backed away from the tent the bike was suposed to be parked under
this let me scrape thru
it wasnt too loud really, but the random bing noise coming from the pipe was pushing it over the limit
im gonna get a washer that fits between the silencer and pipe for next time in case theres issues
jbsleddin
Post by jbsleddin »
NightBiker07 wrote: The more i read into these, the more i want one for my bike.
I am thinking the same thing but having trouble admitting it. It's like your first AA meeting, admitting you have a problem. :lol:
I started making them when I blackened my foot almost this bad...
bearorso
Post by bearorso »
mr500 wrote:Who said its easier to start?.. Decomp means it's only easier to Kick!
BIt like an xr400.
It bloody well should start easier. There's not much bloody point if it doesn't. It shows it to be an ill thought out design, however pretty it might be.
Does your bigger tank still fit?
I posted my Auto Decomp pics and info in July 07, on CR500riders . SH and Roosty seemed to have got into them, then.
Mine, you just kick the bike, and it goes. No levers, buttons , TDC finding, or anything to mess with. Fit any tank you want. I don't try to sell them on sites, as I've more than enough to do, but I've done quite a few for people who have sought me out. Unless I'm 'snowed under', if a OZ owner sends his parts (head, and carb) to me by Express Post, they get the finished job back, in less than a week from when they sent their stuff.
DonDDR
Post by DonDDR »
What is an ill thought out design? What am I missing when you say that? Its late and I might not get it right now...
Id like to see your design, or sell me the plans to do myself?
