CDI wire locations
CDI wire locations
I need to know what location the wires are in on the 2000-2001 CR250 ignition at the CDI plug
with the clip to release it at the bottom / towards the steering stem i think, what colors are these numbers?
mxdogger
Post by mxdogger »
Adam heres the color code, this is looking at the connector from the backside like your picture shows.
1.blue
2.black w/white stripe
3.black w/yellow stripe
4.blue w/yellow stripe
5.white
6. black
7.green
8. green w/white stripe :cool: :cool: :cool:
EXCELLENT!
thanks!
ok, i've changed the harness arround a bit. the 2002 is a snakes den
the blue and white are the generator, i cant see it making any difference which way they go, but they dont match, must have been opposite locations in other years
fastkart
Post by fastkart »
Roostius_Maximus wrote:the blue and white are the generator, i cant see it making any difference which way they go, but they dont match, must have been opposite locations in other years
When I wired my MSD unit to a '97 250 stator I assumed the wires for the generator didn't matter as well. After chasing my tail because it wouldn't start, I swapped them around and it lit up.
Ok, I just swapped the wires so they matched how the images were incase of polarity or whatever you'd call it in a stator
