I was going to buy it, but he wont ship to Canada.......
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT
WE HAVE HERE A 1999 HONDA CR250 ALUMINUM CHASSIS, PROFESSIONALLY MODIFIED (AND POWDERCOATED) TO BOLT IN ANY CR500 ENGINE. THE ENGINE PICTURED IS A 1985 CR 500 ENGINE THAT IS OVER-BORED BUT OTHERWISE STOCK. THE CLUTCH COVER IS UPGRADED TO A LATER MODEL COVER WITH THE CLUTCH QUICK CHANGE SMALL COVER. THE ENGINE HAS HAD A DRAIN PLUG REPAIR DONE USING A THREAD INSERT AND ALSO THE SMALL CLUTCH OUTER COVER HAS A SMALL HOLE, BUT LARGE COVER IS BRAND NEW WITH NEW WATER PUMP SEALS AND BEARINGS. PLEASE EMAIL ANY QUESTIONS!!! HERE IS THE LIST OF EVERYTHING INCLUDED
*MAIN CHASSIS WITH ENGINE INCLUDED ( HAS STATOR BUT WILL NEED FLYWHEEL AND CDI) (*2001 CR 250 IGNITION WORKS GREAT ON THESE MOTORS!)
*UPPER AND LOWER TRIPLE TREES
*BRAND NEW SUBFRAME/ AND USED AIRBOX
*40 MM KEIHIN CARBURETOR, AND 39 MM KEIHIN (STOCK CR250 CARB)
*FRONT WHEEL WITH DISC
*COMPLETE SEAT
*VARIOUS PLASTIC(DISC GUARD, FORK GUARDS, FRONT FENDER)
*FUEL TANK W/ CAP
* REAR CALIPER, BRACKET(BROKEN) AND MASTER CYLINDER
*TAPER HANDLEBARS
*CPI OUT-OF-FRAME DRAG PIPE (HAS HAIRLINE CRACKING AROUND FRONT BUT CAN BE REPAIRED)
*ENGINE GENERATOR COVER
THIS AUCTION IS MAINLY FOR THE MAIN FRAME AND ENGINE BUT ALL PARTS PICTURED ARE INCLUDED. MOST ALL PARTS WILL NEED SOME TLC BUT ALMOST A COMPLETE BIKE FOR A LITTLE MONEY. IF U HAVE A 97 UP CR 250 WITH A BLOWN ENGINE U CAN HAVE A NICE 500 AF WITH THIS PACKAGE. SHIPPING WILL BE BASED ON YOUR ZIP CODE, AND LOCAL PICK-UP IS OK!!! THANKS AND EMAIL QUESTIONS BEFORE BIDDING!
ebay find: Gen1 CR250 converted. With 85 500 motor.
buy it, ship it to 1800hwy32n, walhalla, nd, 58282.
I'll bring it in
I'll bring it in
pretty sure i know a dude thatd buy that pipe for the snow bike
call me if you want me to work on getting it for u
