Need new bars
tadiv
Need new bars
Post by tadiv »
My handlebars are tweaked, what do you recommend as a cost conscious replacement?
Turn.
bigpower
Post by bigpower »
Pro Taper CR High Bends
Spend the jack....after all, this IS where you hang on from. If you ever had a bar break on ya when riding, you'll be grateful for the extra piece of mind
tadiv
Post by tadiv »
Bend - Yes
Break - WOW! Not yet!
Turn.
ou812
Post by ou812 »
I,ve had a frame fail while riding but never a bar
bigpower
Post by bigpower »
And you don't ever want a bar to break on you, either.
Not a pleasant experience, so stay away from the "Cheep" shit. Or used ones on eBay.
I think I like the flexx bars with the inserts for the 500 kinda hard to get use to but after you do and the ride one with out a set man what a differnce but the are spendy
tadiv
Post by tadiv »
You know, I have noticed a theme in life. Not always, but most of the time when you lay out the cash you end up with something you really like. That does not happen much when you try to cheap it out. Not always, but close.
Turn.
ou812
Post by ou812 »
Holds true with beer anyway.
zorak-2
Post by zorak-2 »
Just due it once get the Pro Tapers or even some Renthals. Because if you bend the steel set them you have to buy another set. 3 sets of steels and you are at the same cost as a set of Pro Tapers.
This site rocks
GEN 4 CRF500
