I have a once used one that EG modded 4 me. I'm sure lewisclan will tell me to reuse it w/ a bit of paint and some chewing gum, no offense J.
modifying a honda head gasket for overbores
Has anyone got any experience enlarging the OEM gasket to 91mm. I'm not sure how to go about it other than to order a cometic. I've been told cometic has larger ones. I own the OEM that came in the motor kit.
X2 LET HER BUCK!!!lewisclan wrote:yep copper coat spray & throw it on
the water holes choke the path of least resistance so that the entire cylinder has the same amount of heat transfer. The old jugs with the rear inlet had the front 2 holes open the entire waterjacket size, and maybee 3/16 size holes thru the other waterjacket openings.
Re: modifying a honda head gasket for overbores
unless you are cutting the head back also what would the gasket hurt?seanmx57 wrote:Has anyone got any experience enlarging the OEM gasket to 91mm. I'm not sure how to go about it other than to order a cometic. I've been told cometic has larger ones. I own the OEM that came in the motor kit.
I have a once used one that EG modded 4 me. I'm sure lewisclan will tell me to reuse it w/ a bit of paint and some chewing gum, no offense J.![]()
