Hi guys,
Bought a complete '88 in really good condition and got a big pile of spares too.
Think I've got enough spares to build a second practice bike, but I've got a mix of parts from different years.
I've got 2 complete bottom ends - an '85 and an '88.
The '85 cases are useable, but the crank has a tight-spot.
The '88 cases are corroded at the waterpump and have a couple of chips around the countershaft sprocket area, but the internals are OK.
I was thinking of using the '88 crank in the '85 motor but will need to fit a 5mm cylinder spacer to compensate for the '88's longer rod length.
Alternatively, I could get the '85 crank refurbished.
To anyone who's done this before - what would be the preffered solution?
Does anyone have any photos showing repairs to damaged / corroded cases with which I could compare the damage to my cases?
If my '88 cases are repairable, I may try this instead of mixing the engine parts.
Repairing the cases (if possible) would be alot cheaper than buying replacement ones.
Are there differences in size of the swingarm bushes from '85 to '88?
The motor will be going into an '87/'88 frame once it's ready.
Cheers for any help.
Ross
									Mongrel '85 / '88 Motor Rebuild
'00 Husaberg FC600
YEEEEHHHA!
						'00 Husaberg FC600
YEEEEHHHA!
Here are some photos of the damaged engine cases.
'88
http://i267.photobucket.com/albums/ii31 ... amage1.jpg
http://i267.photobucket.com/albums/ii31 ... amage2.jpg
http://i267.photobucket.com/albums/ii31 ... amage3.jpg
http://i267.photobucket.com/albums/ii31 ... osion1.jpg
http://i267.photobucket.com/albums/ii31 ... osion2.jpg
http://i267.photobucket.com/albums/ii31 ... osion3.jpg
http://i267.photobucket.com/albums/ii31 ... osion4.jpg
And the '85
http://i267.photobucket.com/albums/ii31 ... Damage.jpg
I reckon a good welder should be able to patch-up the missing / chipped areas, but I'm not sure if the water pump area on the '88 is too bad to try and fix -
What do you guys think?
Cheers,
Ross
									'88
And the '85
Cheers,
Ross
'00 Husaberg FC600
YEEEEHHHA!
						'00 Husaberg FC600
YEEEEHHHA!
Here's some photos of the complete '88.
http://i267.photobucket.com/albums/ii31 ... CR5001.jpg
http://i267.photobucket.com/albums/ii31 ... CR5002.jpg
http://i267.photobucket.com/albums/ii31 ... CR5003.jpg
http://i267.photobucket.com/albums/ii31 ... CR5004.jpg
http://i267.photobucket.com/albums/ii31 ... CR5005.jpg
'00 Husaberg FC600
YEEEEHHHA!
						'00 Husaberg FC600
YEEEEHHHA!
