Air Box which one works for each gen?
I need to know which one for the gen 3, but can we get a list of what works for all gens starting with gen 1?
Re: Air Box which one works for each gen?
You'll be just fine with the stock one.Ported&Polished wrote:I need to know which one for the gen 3, but can we get a list of what works for all gens starting with gen 1?
From what I've heard, if I remember right, get the carb clamped into the airbox first, then clamp the carb onto the manifold. I heard some guys say they fought with a bit, others said peice of cake.
The Gen 3 boot/airbox is junk. The boot is flush mount and that's just asking for trouble. That and the filter cage is flimsy and the boot mounting nubs get in the way of the filter.
I've modded my airbox to accept the older double-lip boot and the steel airfilter base. With that, you can run the older/stronger filter cage.
I cut out the filter base just inside of the bead used to allign the stock flush mount boot. I then drilled out the mounting nubs and used a Dremel tool to remove the bead.
I tried a '01 CR250 boot first and that's kicking the carb so far to the left that it's touching the lower intake bolt. I'm going to try a '98 CR250 boot and see how that works. If it does, I'll use some 3M weatherstrip glue to seal it all up.
So, for Gen3 250 builds, the stock boot or, hopefully, a '98 CR250 will work. I just wouldn't recommend the stock one.
Yeah, I know a lot of folks were running their set up. Mxbonz.com also sells a nice fix.mxracr121 wrote:He has the the PC Racing airbox ring on his between the boot and airbox, plus extra silicon to be safe, so it doesn't have the stock problems. I never had any dirt or water get in.
I went this route because, if you think of the route dirt would have to travel on a flush-mount boot, it's not much. Think about what it has to travel on a sealed double-lip boot, well, it's a hellova' lot.
There's a thread on Thumper Talk where a guy used a '98 boot on a '02 CR250 box. That's why I mentioned '98. Not sure about the '00.2weelz wrote:I thought the hot ticket was the 2000 boot. I read somewhere that the '00 and '01 had different carbs and the 2000 boot worked great unlike the '01. I think it fits right up to the carb. Not sure, though.
I did some more fitting of my 03 airbox and boot to the carb, it is not a very good alighnment. I don't have the boot to carb clamp, so I'm not sure if I can force fit the 3 parts together well enough. It will be tight, and the rubber parts will be stretched some for sure. But it may work, at least for now. I will try it and if I don't like it, I will get the recommended stuff you guys used.
yeah, I had to use the newer intake boot on my '86 motor. but the newer ones are smaller at the opening, so I matched it to my reed cage. On my gen-1 the air box boot didn't fit quite right, so I got it nice and hot with a heat gun, than put everything together and clamped everything, then withg it installed I heated it a couple more times and let it cool. now it sits that way natually and fits like it was make to.
- maddog1927
I am shoping flea bay for an air box for my third gen.hagendog wrote:I used an 06 125 airbox with a 03 boot, no leaks like the 02-03 did and fit perfect. The 06 boot had a weird angle on it
So was there a change in design of the air box / air boot connection in '04?
Did they return to the steel hardware, and the grooved boot?
What year range should I be looking for?
