Help - Steering stem dimensions required
I have run into a problem with my ice sidecar front end
I need the ID of the bottom taper bearing on the sterringt stem for a 98.
Does anyone have either the bearing or a stem they can measure for me?
Hopefully it is 26mm like the upper bearing!
Thanks
BobM
Thanks
BobM
Re: Help - Steering stem dimensions required
The problem I'm having is matching a 86XR600 front end onto the 98 CR500 frame.
Looking at the fiches on line, the same bearing is used for the bottom of the CR500 steering stem from 90 thru 2001, Honda part number 91015-KZ4-701, unfortunately I can find no dimensions online for this bearing.
I urgently need this dimenesion as I dont want to buy and find the bearing is the wrong size.
BobM wrote:I have run into a problem with my ice sidecar front end
Thanks
BobM
The newer steering stems are tapered they are larger at the bottom.
A newer style bearing will not fit on an older stem unless you are ok with it flopping all over the place. I suppose you could have a bushing made.
When I put a newer USD front end on an 87 I could not get a bearing to accomodate the larger lower diameter of the stem so I had it machined down to the same size as the top so I could use the older style bearing.
Bearing size
Thanks, that means we need a 2mm thick sleeve to make the old stem fit the new bearing.
Thats doable, other options were a lot less attractive?
By the way, have you ever found a non-Hoda source for sterring head bearings? They all seem to be non standard OD's & ID's
BobM
BobM
