electrical gremlin?
electrical gremlin?
Ok, so i sorted my last problem with an air leak out, now another issue. The bike started intermittently cutting out, very minor at first, but eventually acting like i was pushing the kill switch. I disconnected the switch, but still acted up, even completely dying a time or two. It seemed to mostly do it under a load, not too much at idle. new plug, same deal. I am thinking coil possibly? Am i on the right track?
- Sandblaster
Start with checking all grounds, then look for broken insulation on wires.
plug wire and cap, stator, coil, CDI that is about everything unless you have a plugged vent in your gas cap
If you have another bike around that you can swap parts with that helps to locate problem areas too.
Where are you located?
