a ? for those of you running boyesen clutch cover
- maddog1927
what do you do when your paper gasket is toast. Where do you get a new one from, or do you use a liquid gasket?
High temp is good, also u can specify which ones you want. Paper or the o-ringt style, that's what I did anyway
Last edited by Flatbiller on February 3rd, 2011, 10:01 pm, edited 1 time in total.
- maddog1927
Its olny $6.95 get a new one. Or get two and you will have one the next time you need one Just say-n
- caseyracing222
- caseyracing222
I have both Boyesen covers on my bike (95CR500) and they were also on there when I got it. I haven't had any problems with them. I just installed a Hinson basket and the clutch cover was glued on with Hondabond and never leaked a drop. Bad side of it is that shit is hell to get off.... until I decided to use a little aircraft stripper on its ass. Put a little in a cup and q-tip it on because it will also take off the paint if your messy but it bubbles up the Hondabond in minutes. After I got that stuff off I re-sealed the cover with Permatex Ultra black and again no leaks plus the Ultra black rubs off soooo much easier. I don't see the reason to get all worried about a paper gasket unless you really feel the need to spend $6 or $7 bucks plus shipping for them.
- maddog1927
